I know it's different in every make and model but for just a guideline how do a Ignition switch work? I know about the the ignition system but how do electricity follow from the switch down to the ignition coils?
    It is just a switch like any other switch, including the light switches in your house.
    – HandyHowie
    Commented Jul 27, 2016 at 12:02
    So when turn that switch it allow the currency from the battery to flow up through one wire then flow to the ignition coil or computer (based on your mode) to the distributor or to the spark system?
    – LostPecti
    Commented Jul 27, 2016 at 12:04
  • That's correct.
    – HandyHowie
    Commented Jul 27, 2016 at 12:13
7
Basically, your car has several circuits:
Always On - Connected directly to the battery and is not affected by the ignition switch. This includes: alarm, interior lights, brake lights, headlights, computer memory (radio, ecu, tcm, bcm)
Accessory - Items that the driver needs, but are not necessary for the vehicle to run. These include: radio, HVAC, windshield wipers
Run - These items are necessary for the engine to run. Items include: ecu, fuel pump, coils(s)
Start - This circuit runs the starter.
The ignition switch controls which circuits get power from what position it is in.
Key position:
ACC: powers the accessory circuit
RUN: powers the accessory and run circuits
START: powers the run and start circuits
I would like to also note that many igntions switches have and UNLOCK position that allows you to turn the steering wheel (and possible shift out of park) while none of keyed circuits are active.
  • So in a sense there's different wires that active st different key turn's? And the ignition coils get power at the run stage?
    – LostPecti
    Commented Jul 27, 2016 at 12:16
    So when you turn the key it actives a cylinder in the plastic or rubber housing which move and click in place based on your key position? Am I right?
    – LostPecti
    Commented Jul 27, 2016 at 12:19
  • Correct. You can think of it as a 'keyed switch'. Ignition coils are on the run circuit and get power in the run and start positions.
    – rpmerf
    Commented Jul 27, 2016 at 12:20
    Thanks man you guys are awesome in helping learn a very large and different subject that is the automobile ;)
    – LostPecti
    Commented Jul 27, 2016 at 12:41
Adding to rpmerf's answer, in cars equipped with an immobilizer they are an integral part of the ignition switch and electronics, so probably worth a mention.
There's a few different types but the general idea is:
  • A key with an RFID tag or something more advanced in it.
  • A ring around the ignition switch, or other sensor at the switch, that can read the code off the key.
  • An immobilizer control unit in line with the starter motor wiring that does not allow the starter to receive power if the presence of the correct key is not detected.
  • Software in the ECU that does not provide signals to the ignition system if the presence of the correct key is not detected.
This makes it more difficult to hot wire the vehicle. They're supplemental systems for the usual ignition wiring. They don't generally affect the ignition switch directly, but instead act as a second line of defense after the switch to prevent the car from running if the correct key is not physically present, and they are part of the path "from the switch down to the ignition coils".
These systems are mandatory in Germany, UK, and Finland since 1998, Australia since 2001, and Canada since 2007 (says Wikipedia). Even in countries where they are not mandatory they are still very typical.
There's also often other switches and such that can prevent the starter from starting the vehicle (by disrupting the electrical connection to it) such as the shifter switch on an automatic (making sure you e.g. can only start the car in park/neutral), the clutch pedal switch on a manual (making sure you can only start the car with the clutch open), etc. You'd have to check the wiring diagrams for your car. Here's the relevant portion, as an example, from a 5th gen Honda Prelude:
There you can see that the immobilizer (along with the shifter / clutch switch) have the power to prevent the starter cut relay from closing, thus preventing power from going to the starter. The ECU (not shown here) also cuts power to the fuel injectors if the physical key is not present (so you can't e.g. hot wire then bump start it).
  • Thanks for the information. Weird as I was just researching this topic ;) thanks for the add on
    – LostPecti
    Commented Jul 28, 2016 at 15:50
