Swapped out LED taillights and third brake light on my '05 Sierra. Tail lights work fine but the third brake light will work when first plugged in but after a short while the cab lights don't work.
If you pull the LED out and replace, then it works again the first time? – Pᴀᴜʟsᴛᴇʀ2♦ Jul 24 '16 at 15:14
Want to clarify - does the brake light work more than once? Do the cab lights stop working when the brake light stood? – dlu Jul 24 '16 at 15:45
Add a comment
