I changed the oil on my 2015 Honda Accord LX myself for the first time. Following a YouTube video, I reset the Maintenance Minder. The problem is that I didn't note the extra codes that show up on the Maintenance Minder to perform that maintenance.
I'd like to find what those codes were.
Can I do this from the dash or with an OBDII scanner?
I've never really checked but it wouldn't be anything you could do from generic obd2 you would need a scan tool that could talk to either the cluster computer or whatever other computer.
Check your service manual booklet it should tell you what needs to be checked/replaced based on mileage.
