There is a new leak at the rear driveshaft. What could this be and how do i fix? Mechanics cost too much and are unreliable (past experience) the repair manual said if it leaks in the rear the problem is at the front but fr using it so much I lost those pages. HELP?
Asked
Viewed
57 times
You're asking about where the drive shaft attaches to the transmission? Or where the transmission and engine come together? – Pᴀᴜʟsᴛᴇʀ2♦ Jul 16 '16 at 2:33
Where the driveshaft connects to the rear differential. Thnx. ;) – LaTausca Belyew Jul 16 '16 at 2:37
2It sounds like you need to replace the pinion seal. It's a pretty straight forward job and it sounds like you already have a service manual. – Ben Jul 16 '16 at 5:29
1@Ben - When replacing the pinion seal, isn't there consideration given to the preload on the pinion gear? If not done correctly, you can cause bigger issues with the differential itself, at least on most differentials I've dealt with. – Pᴀᴜʟsᴛᴇʀ2♦ Jul 17 '16 at 12:11
@Pᴀᴜʟsᴛᴇʀ2 indeed you want to use an inch pound torque wrench to determine how much torque is required to turn the pinion. You add 5 in lbs when retorquing. – Ben Jul 17 '16 at 14:18
