7
I need to remove the alternator from a 1.3 4E-FE engine in a 1998 Toyota Corolla, but have ran out of ideas to do it. This is the photo of the alternator in situ:
To the right of the alternator is the pivot bolt which is what is holding the alternator to the bracket which is connected to the engine. I've removed the nut so the bolt should be able to be removed, but I'm not able to do this. I've taken several spanners and ratchets to the bolt head but I either have no room to get a good fit on the bolt or when I do get it to fit I have no room to turn the tool.
I then tried to unbolt the bracket from the engine, but I have the same problem. No real space for me to get a ratchet in or enough room to move it.
I have had a friend suggest I take a crowbar to it with the hope of breaking the bolt, but I'm afraid of breaking the bracket holding it to the engine block.
Has anyone got any ideas on how I can get this alternator out? The adjustment bolt broke off at the top of the alternator so I need to remove it to get this bolt out, as well as change the bearings inside the unit.
  • Shouldn't the pivot bolt just slide out if you've removed the nut?
    – Zaid
    Jul 14, 2016 at 7:52
  • It should, but it's tight as hell. To move the alternator in to the position I did I had to use a crowbar and push against it with my weight. Jul 14, 2016 at 7:53
    Did you try rapping the free end of the bolt with a hammer to encourage it out? I'm not sure why you have to get a spanner/ratchet around the bolt if the nut's already undone. Unless the bolt is threaded into something else..
    – Zaid
    Jul 14, 2016 at 7:57
  • I took a hammer to the left hand side of the bolt, where I've already removed the bolt and it doesn't budge. The only thing I think it could be threaded in to is the bracket. Jul 14, 2016 at 8:17
    It's probably corroded in place you may need to take some heat to it.
    – Ben
    Jul 14, 2016 at 12:11
It depends what tools you have available and whether you are replacing the alternator. I would probably resort to using my air hacksaw to cut through the bolt just inside each end of the bracket. This will release the alternator. The alternator should be reusable, maybe just needing a washer or two to make up the space cut by the hacksaw. Of course you would need a new bolt.
After much messing about, research, cut hands and many a swear word I got it off.
In the UK (where I'm from) something was recommended to me on another forum called Plus Gas. It's a penetration fluid, like WD40, but better. It's thicker and stays around much longer than WD40. I sprayed this on the hinge of the bracket and started to pull it back and forth. It was still a bit stiff but was moving more freely until I hit the bolt with a hammer. The alternator then became very loose. What I then noticed was the bolt was stuck in the alternator itself.
I bought some six sided sockets and started to pull the ratchet towards me and push the alternator away from me (to help the movement). I did this for 30 minutes and didn't make much progress. Out of frustration I started hammering the bolt again, but I noticed that the bolt was actually moving. So I slammed it a few more times until it was flush with the bracket. I still couldn't get the bolt out though!
I ended up buying a centre punch and took my lump hammer to it, and hammered the bolt all the way out of the alternator and bracket. The bolt has corroded fairly badly inside the alternator. It was also slightly bent.
The crux of the situation though is that this bolt was fitted incorrectly by the previous owner (or their mechanic to be fair). The head of the bolt should have faced away from the engine, not towards it. However on reflection I'm not sure whether I'd have had a worse time removing the bolt if it was fitted properly.
But yeah, Plus Gas (or 50/50 mix of Acetone and ATF fluid), a centre punch and a lump hammer. That's what you need to remove an alternator from this car!
