When heading to the store to pick up a new set of spark plug wires, I found three products at this particular shop:
- Product #1:
- Price: Cheap
- Boots: EPDM
- Core: Suppression
- Insulation: EPDM
- Max Temp: 356F
- Product #2 (labelled "Gold Series"):
- Price: 2x Product #1
- Boots: EPDM Top, Polyester Tube, Silicone Tip
- Core: Suppression
- Insulation: Silicone
- Max Temp: 482F
- Product #3 (labelled "High Performance"):
- Price: 4x Product #1
- Boots: Silicone
- Core: Spiral
- Max Temp: Unknown, but presumably high given silicone use
Electrically, these just all seem to be wires that move electrons around and successfully fire the spark plugs, all presumably large enough to handle the required currents, all presumably with resistances in an appropriate range.
Product #3's description states (emphasis mine):
[These] wire sets utilize a construction method known as "variable pitch" wire winding to create resistance to radio frequency interference. They have a lower resistance than conventional carbon core wires, which translates into longer wire life. At the center of each wire is a fiberglass stranded core, made from the same family of materials as those used in bulletproof vests. This core greatly enhances the overall strength of the wire and prevents the pulling strains that wires are often subjected to. They feature custom-designed terminal boots that provide an exact fit and high-quality EPDM and silicone coverings to resist high temperatures, oil, and chemical damage. Each wire is fitted with a positive-locking, corrosion-resistant, nickel plated terminal end for a tight fit and maximum resistance to vibration and separation.
So my questions are:
- Do "high performance" spark plug wires affect how the vehicle runs in the short term and, if so, how? I can't imagine what effect the wires could possibly have but their marketing departments have successfully kicked me into full consumer-mode and hooked me with the word "performance" and a high price point.
- In any case, it seems like the major difference is simply durability, given the description of product #3. Is this true, and does this justify the extra cost (e.g. if an expensive wire has an expected lifetime less than 4x a cheap one, but costs more than 4x more, why would I buy it)? I imagine even the cheapest will last many tens of thousands of miles or more, though.
