To start I have a lot of deletes and tuned ecu on a B18 bottom end with B16 top. Turbo has been set to cut out at 5psi on the ecu. I have a good feeling it is something fuel as I am having problems keeping any pressure in the fuel lines to keep it running. I have powered the pump alone and it works. I put my fuel pump relay in a friends car and it works. Brand new fuel filter, fuel pressure gauge attached. it now won't even start. What could be going on??
1So what does the fuel pressure gauge read while cranking? – SteveRacer Jul 13 '16 at 4:28
How did you power the pump? Did you jump the relay terminals? What's fuel pressure? How about fuses? Voltage drop? – Ben Jul 13 '16 at 22:51
List your deletes. – tlhIngan Jul 14 '16 at 0:44
