I'm currently having issue where my ac unit will turn off and back on. My idea was going towards a shortage in the blower motor wire because when I move it around the unit turns on. I've had this issue for over a year. It also happens with the heating also. That's why my mind is saying a wire issue. Can anyone help me? If it is a wiring issue will I still have to replace the entire blower motor?
If you can move the wiring and the blower motor turns on disconnect the connector and look for proper fit, burned wires, loose terminals etc... It may just need a new harness connector. If the wiring is burned replace the blower motor as well as the connector.
Ok, thanks. I looked for bad wiring before but it seems to be in good condition. I also tested the connection from the blower motor itself to see if it's getting fire to it, just as well as the fuses. I have yet to check the end that the harness connects to. I some how left that out lol. Thanks again – Shirneke W Jul 10 '16 at 14:34
