I want to know how would a camshaft ( and valves by association ) start moving on a cold start up? What gets them running and moving. Are there something they connect to to get them going?
For mass-produced engines, there is nothing special going on with the camshaft(s) on cold start - they will always be driven by a timing chain or belt off the crank, regardless of whether the engine runs hot or cold. – Zaid Jul 9 '16 at 19:23
Crank shaft has a pulley or a sprocket at the front end, which turns a cam shaft/shafts through a cam chain or cam belt (timing belt). 1 turn of a cam shaft = 2 turns of a crank shaft. At the other end of a crank shaft is a flywheel which being turned by a starter motor for a start. Crank shaft is the first shaft in the whole engine which turns everything else.
yea, just noticed :D Just a random pic from google. Looks like a 1-2-3-4, never seen that before! – Arturs Bolsunovskis Jul 9 '16 at 19:21
@user15938 - If this answers your question, please feel free to check it as the answer :o) – Pᴀᴜʟsᴛᴇʀ2♦ Jul 9 '16 at 21:54
