In an effort to design a theoretical engine capable of outputting 3000 horsepower, I was hoping to emulate the 10.2 liter Chevrolet V8.
What are the specifications for this engine? I was hoping for the cylinder bore & stroke, as well as the piston style, valve train, etc.
  • Can you explain in more detail what you are wanting to know? Commented Jun 30, 2016 at 8:36
  • @Peter engine's full specs about cylinder bore, piston, crank and rod length Commented Jun 30, 2016 at 10:02
    Possible duplicate of Designing IC engine
    – JoErNanO
    Commented Jun 30, 2016 at 13:27
  • @JoErNanO yep. Same guy. Slightly different question. Commented Apr 11, 2020 at 2:01
A Chev 622ci = 10.2l
I found dimensions for a Chev 632 cubic inch =10.3l
Stroke: 4.750"
Rods: 6.635"
Bore: 4.600"
Taken from here: http://www.jegs.com/p/Blueprint-Engines/Blueprint-Pro-Series-Big-Block-Chevy-632ci-815HP-800TQ/1321871/10002/-1
The horsepower output you're talking about would require forced induction. So turbocharged or supercharged.
Here's a twin turbo 3000 hp chev http://www.engineswapdepot.com/?p=3661
  • I've seen a lot of ads for 622ci which is right at 10.2L ... you may want to take a look at them and adjust your answer. I've not seen any at 3000hp, but it would only take a pair of twin turbo's to make it happen. (Haha - I said only a set of twin turbos, lol! As if that wasn't enough already!) Also, Top Fuel Dragster is more like 8,000hp ... so we are well below that threshold. Commented Jul 1, 2016 at 17:00
