So I have a 2012 convertible V6 Ford Mustang and there is a very small crack developing in a crease on my roof:
Vinyl Tear
I believe the top is made from Vinyl and I must confess that I've neglected it. The first 2 years of the cars life were outdoors and I tried to clean off crud with water when it got on there, the last 2 1/2 years have been garaged and the car has only been out in good weather.
How can I mend this tear, and what kind of stuff do I need to treat the top with to prevent this from happening again? I'd like for this baby to last!
Here is a slightly larger view of the roof - I'm pointing at the location of the crack:
Crack Location
You could try a flexible epoxy or something like a cloth/heavy-duty repair tape: http://www.gorillatough.com/gorilla-clear-repair or https://www.mcnett.com/gearaid/tenacious-tape#10691
  • Thanks! I ended up going with "Loctite Vinyl, Fabric and Plastic Repair Adhesive". The link is not to specifically advertise a product, but so that others can see the gist of what I purchased. It's clear and it went on well enough. The crack is small and hopefully this will keep it from expanding! Time will tell.
    – Shrout1
    Jul 27, 2016 at 16:03
  • Must confess that the Loctite adhesive did not last very long and wasn't effective. Sold the car about a month ago and the crack had not increased in size too much. Prevention or replacement seem to be the only good options...
    – Shrout1
    Sep 11, 2019 at 17:47
