I feel like the A/C in my 2012 Chrysler Town & Country is under-performing. So, I measured the A/C temperature output on it and my 2003 Toyota Corolla, and I'm having trouble reconciling the results.
Here are the experimental results, based on this setup:
Vehicle | Outside Condition | Temp Setting | Fan Setting | Measured Output Temp
Town & Country | 85°F / 55% rh | Coldest - "LO" | Min ("1" bar) | 42°F
| Coldest - "LO" | Max ("6" bar) | 60°F
Corolla | 94°F / 35% rh | Coldest | Min ("1") | 45°F
| Coldest | Max ("4") | 49°F
(These results show that as the blower speed increases so does the output temperature. This Q&A explains why in lay terms, or see also this technical summary. For a general guide on auto A/C implementation, see this article.)
But why does the Toyota increase 4°F, while the Town & Country increases 18°F? I'd expect a significantly newer vehicle to have the same or better A/C output performance. But no: in the Toyota, one tick more on the blower is one degree up in temperature. In the Chrysler, one blower tick up is four degrees up.
That doesn't make sense to me. Is the A/C on the Chrysler under-performing, and I should spend the cash to have a pro look at it: or is this all just about perception, and I should be happy with it?
Update: Indeed, the A/C was under-performing. The low pressure side was at 20 psi, where nominally it should be around 30 psi. I took it to a pro, who found a failed thermal exhaust valve. Replaced the valve and recharge recycled the refrigerant. Now it blows 48°F at coldest with the blower on maximum. This is inline with the performance from the Corolla.
