2016 Subaru Outback won't shut off audio book when answering the phone. Tech at Subaru dealership said it was because I was using one click digital and I needed to switch to audible. I don't believe that . And I won't take that for an answer, I think he just wanted to get me out of the lot.
1What do you mean by what he said, "I needed to switch to audible"?– Pᴀᴜʟsᴛᴇʀ2 ♦Jun 21, 2016 at 21:38
1@Pᴀᴜʟsᴛᴇʀ2 I think she is referring to to different phone apps that play audio books.– MooseLuciferJun 21, 2016 at 21:43
What kind of phone are you using (iPhone, Android, etc)?– MooseLuciferJun 21, 2016 at 21:48
Did you try the suggested fix from the tech? What were the results?– DucatiKillerJun 22, 2016 at 0:33
1 Answer
This sounds more like a problem with the app then the Subaru audio system. I would try playing music or a different app and taking a call. If that works fine, you know it's a problem with the app.
A OneClickdigital Version 2.1 release document available here addresses problems people were experiencing during phone calls on Android devises. If you can update your app, that may solve the problem.
If it does not solve the problem, you may be left contacting the app developers, or finding an alternative like the Subaru tech suggested.
Good luck!
