I took my Nissan pick-up truck to the smog station, and this code appeared. This made it fail the smog test. What can I do to fix the problem?
  • P0705 is a transmission range switch/park neutral switch code. Could be a wiring issue a relay, ECM or switch failure. Is this an automatic transmission? – Ben Jun 19 '16 at 5:33
