-1
Went to mechanic a month ago and need sway bars and new brakes. The last two days it's been very difficult to steer when turning but my tires are fine and I just replace power steering fluid but I'm still having difficulties. Any ideas what could be wrong? 2001 Lexus es300
    Is there any noise (whine) when turning the wheel? This would be most noticeable at lower speeds. Jun 17, 2016 at 9:39
    "I just replace power steering fluid"...do you mean you filled a low reservoir? Or did you actually drain and replaced the fluid?
    – CharlieRB
    Jun 17, 2016 at 17:36
Check the belts on the front of the engine. It's likely you have a slipping power steering or accessory belt. The belt could have stretched, or the tensioner could have failed. Replacing a belt is usually pretty straightforward, replacing the tensioner is a little more involved. If the belt seems loose, you may be able to tighten it using a tensioner (possibly part of the power steering pump assembly, or a simple external pulley). I'd check YouTube for videos first, then possibly see if you can find a repair manual for your car if the videos don't help.
