Make: Honda
Model: Accord
Engine: 3.0L
Year: 2000
Error codes: P0301,P0302,P0303,P0304,P0306,P1399
Knowledge level: I know little about cars
Help needed: Please help me find out what is going on and how to fix it.
    These codes simply indicate misfiring cylinders. Could be many things - spark plugs, coils, high tension leads, vacuum leaks, fuel delivery issues, etc. The question is impossible to answer as it stands, you need to be much more detailed or simply seek professional diagnosis. Jun 3, 2016 at 14:19
  • when's the past time a tune up was done. also how many miles? you may be overdue for a valve adjustment.
    – Ben
    Jun 3, 2016 at 16:11
  • I would start by changing the plugs and wires. Jun 10, 2016 at 4:31
P1399 HONDA - Random Cylinder Misfire Detected
Source of Information: http://www.autocodes.com/p1399_honda.html
Possible causes - Valve clearance out of range - Blocked EGR (exhaust gas recirculation) Passages
Tech notes: Adjusting the valves will usually fix this
When is the code detected? The control module monitors the crankshaft speed and has detected a misfire condition
Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) - Lack/loss of power - Hard start - Engine hesitation
P1399 Honda Description When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Crankshaft Position (CKP) sensor signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring. - Valve clearance out of range
The other codes are secondary codes indicating the cylinder that is misfiring. P0306 for example indicates cylinder #6.
