I have a 1997 Honda accord. The other day I had it started and turned it off went to start it up again and nothing just a click. When I go to start it the battery indicator light comes on and will not try to turn over.my shifter is locked in park, my windows will not roll down, sun roof will not open.but on the other hand the a/c comes on, the lights work,and the radio works.I know its not the starter,I checked all my fuses in and out the car. I need help can some one tell me what's wrong?
Have you attempted to jump-start the car? It sounds like the battery is dead through your description. – nolan May 31 '16 at 20:26
Yes I did it did not work – ian jones May 31 '16 at 20:36
Regarding your windows, did you test them with your key in both the ignition and the accessory position? – elrobis May 31 '16 at 21:23
I did try both in the accel position and the crank – ian jones Jun 1 '16 at 16:01
I'm sure you've thought of this, regarding your windows, is your p/w lock on? – yorTsenoJ Jun 1 '16 at 17:22
