I have a GSXR 600, and the live side of a circuit touched the frame and blew a 30A fuse. I changed the fuse and now I have no power. Does any one now why? Thanks
That may have not been the only fuse, and just because the fuse blew doesn't mean something wasn't damaged a split second before. Does the battery have voltage? Are there other fuses?– JPhi1618May 24, 2016 at 20:17
What power is out, all of it, some of it, we really need more details in order to help you with this.– cdunnMay 24, 2016 at 20:31
Any luck resolving this?– DucatiKillerMay 25, 2016 at 22:05
I have green neutral light on now nothing else no lights ect– CarlMay 26, 2016 at 15:02
Can you edit your question with all of the things you have tested and ruled out? Where exactly is your 30 amp fuse located?– DucatiKillerMay 26, 2016 at 17:50
1 Answer
The thirty amp fuse is your main fuse
To ensure we are speaking using the same nomenclature, K1 is referring to model year 2001 in my verbiage.
This 30 amp fuse supplies all the power to your fuse block with various 5, 10 and 20 amp fuses populated.
I have quite a few hours on this bike and have seen a scenario that you are describing. Here are some recommendations.
Check your 30 amp fuse for continuity with a multimeter. Sometimes they come out of the box bad. Rare but possible
Check your starter circuit fuse under the seat. When you say 'no power' does that mean headlights and everything or no power to turn the starter. Is it a global 'lights out' across the board?
Check all of your lower amperage fuses. Some of them might have been taking out when the incident occurred.
