I have an Honda S2000 2002,137000km.
Yesterday, while running on the Track I lost the two spring bolts on the header/tespipe... so the car started shaking badling and caused my aem v2 intake to loose from the engine but I didn't notice right away so I did another session. I then put two brand new bolts and fit the intake right back into it's place but the car is now only shaking when the RPM is dipping under 1000... it used to idle at 1000-1200 but now it goes as low as 500 and that's when the vibration is making the whole car shaking.
Since I pushed the car really hard on the track while the intake was off the engine I assume the problem comes from a dirty intake, IACV.
p.s: the engine mounts look bad but since it only shaking when it goes under 1000 rpm I don't think it's that
All inputs are welcome.
Thanks
    Do you have some pictures? They might help to clarify the issue.
    – JoErNanO
    May 23, 2016 at 12:51
The reason you are getting the vibration is, the engine should idle at around 800rpm. Down at 500rpm vibration will be a lot more pronounced. You shouldn't get any vibration up at 1000+rpm. I've read reports on other sites people feel it clears up around there. Even at 800rpm there will be a slight vibration.
I'm thinking you already had a vacuum leak at the intake before it popped off, which allowed your idle level to drop drastically after you did your fix. Due to this, you need to probably do an idle relearn, plus clean the IAC and MAP sensor. Here are some procedures from what I've learned today (from this site):
Map sensor
  • Unplugged battery
  • Disconnected the map sensor
  • Whacked on the plug outlet to clear out any debris
  • Sprayed with compressed air to clean out any debris
  • Plugged back sensor
  • Ensured there was a good connection
  • Zip tied it around the plug horizontally and vertically
IAC
  • Unplugged the sensor
  • Unscrewed bolts
  • Tilted over the IAC to get a good view
  • Sprayed carb cleaned into the IAC liberally (unfortunately I was not able to get out all of the black build up) the canal on the side looked cleaned but in the middle chamber there was still some black markings along the side walls, I was afraid of using a Q-tip or brush because it might of left some bristles in there causing more troubles reinstalled IAC with a thin layer of oil reconnected the sensor
  • Reconnected the battery
  • Let it idle for about 15 minutes
  • Took it for a drive and NEVER COASTED only downshifted through all the gears until 2nd where I preceded to wait till 1k before I clutched in and braked completely.
Mind you, this was copied directly from the forum, the advice appears sound.
