After replacing the O2 sensor due to fault codes 1166 and 1167, I still get 1167-Heater circuit error. I check resistance through O2 sensor heat, about 17 Ohms. Plug has 14 volts feeding heater. I read somewhere that computer has to re learn parameters to get CEL to go out, after running several hours/cycles. Is this true?
1Did you clear the codes after putting the new O2 sensor in?– Pᴀᴜʟsᴛᴇʀ2 ♦May 18, 2016 at 21:25
@LynnCrumbling your comment should be an answer– MoabMay 18, 2016 at 21:57
im assuming he did clear the code since he said only 1167 came back.– BenMay 18, 2016 at 22:19
The sensor heater Ohm reading is about right for a typical regular Oxygen sensor. It is too high for a typical Air Fuel Ration sensor. The PCM will set this code it the ohm reading is incorrect. The exact vehicle would need to be known to say for sure. A VIN would be helpful. There are several variations of the engine control system in these cars. Some had significant issues.– Fred WilsonMay 19, 2016 at 2:35
1 Answer
As @FredWilson pointed out, there is no relearn for a heater circuit code.
On a 2.3
Check for power at the ECM connector C pin 13 (white).
On a 3.0
Check for power at the ECM connector C pin 1 (black/white).
While the o2 heater wire may have power there may be a break in the wire that goes to the ECM. This wire tells the ECM that the heater relay is working.
