More and more trucks in the UK seem to have these yellow triangles on the wheel nuts. Usually in pairs pointing at each other, but I have seen one truck that had them all facing the hub.
What are they for?
Sign up to join this communityMore and more trucks in the UK seem to have these yellow triangles on the wheel nuts. Usually in pairs pointing at each other, but I have seen one truck that had them all facing the hub.
What are they for?
If you are talking about these, they are there to indicate the torque or the bolt has not loosened any. They are just an easy visual sign the lugs have not loosened any.
Part of the way down on this page which reviews lug nut torque indicators, it says:
To assist with making sure that there are no loose lug nuts on a truck which can give rise to "wheel separation accidents," there is an invention that we call "lug nut torque indicators" that we have seen installed (mostly on the steer tires) of some trucks. The Wheel-Check.com website refers to these as "loose wheel nut indicators."
EDIT: Just so you know, they are becoming prevalent here in the US as well.
EDIT2: For better understanding, these are put on after the lugs are torqued, in a recognizable pattern. If a lug should turn (and thus have lost torque), it would immediately be visually recognizable as such.
