I've been asked to find parts for a Farmall H Tractor carb.
None of the searches I try identify the Make and Model.
I believe the engine is an IH C152. I can see that the same carb is used on an H, HV & W4.
Did Farmall make their own? or are they OEM Holley/Zenith etc
I can't inspect it myself but have been told the main jet has been damaged and repaired in the past. Im trying to find out what it is do i can make enquiries about parts before i get there.
  • Ugh. After much delay the tractor engine turned out to be a Farmall M. (In a Hamilton grader conversion.) Carb was stripped and cleaned and torn gaskets replaced and it is now running again. Commented Aug 14, 2016 at 6:41
They used different manufacturers and models of carburetors through the years, or it could have been replaced with a different kind. You are best to pull the carb and gently clean it to find mfg or model numbers stamped into the throttle base or on a tag
http://www.steinertractor.tv/Wrenching-with-Rachel/How-to-identify-your-carburetor/189272--3848536
  • Im not able to get my hands on the tractor myself. Ive been told the main jet has been 'mangled'... so i was hoping to find either a carb kit or a whole replacement before i start work on it. Commented May 15, 2016 at 10:10
  • I see its possible to buy a new replacement carb, but that seems excessive. If i can identify it i hope to find a 2nd hand carb or a kit. Commented May 15, 2016 at 10:15
  • @Peter let us know how it goes.
    – Moab
    Commented May 16, 2016 at 18:33
