I just bought a 2013 VW Jetta SE with a 5-speed manual trans. I'm new to Volkswagen, and I found this part in my glovebox. Does anyone know what it could be?
  • Any pictures of the front or is it blank?
    – Ben
    May 9, 2016 at 0:02
  • I can't place it. I have a 2011 Jetta, and I've never seen it (NOT a definative answer). My guess it that a detail guy found it when cleaning and put in in the glovebox just in case it was related to the car. I'll give it a 50/50 shot of actually being a part of the car.
    – JPhi1618
    May 9, 2016 at 12:58
    Does it have any numbers stamped onto it? Most VW parts, even little pieces of plastic trim, typically have part numbers stamped or cast into them. May 9, 2016 at 13:28
  • Showing it from multiple angles could help. As @SteveMatthews stated, look for numbers on the component to post in here. May 9, 2016 at 20:22
  • Between the "clips" there are raised numbers. POM 15
    – Alex Volpe
    May 10, 2016 at 20:25
I used to own a VW and it looks like a switch cover like for flashers,heater, etc.
