I am getting cylinder misfire OBDII error codes after performing a cylinder leakdown test. During the test, I was turning the crankshaft to reach TDC for each cylinder and I'm now thinking whether it needed to be readjusted again (to a startup position) in order for the firing to run. The engine is on and running but slightly shaking and the check engine light is on (which is why I got the code readings). Or could moisture (it was mildly raining) have affected the connection between the ignition coils and the spark plugs?
Toyota Tacoma V6 2007.
