8
My 2007 Tacoma loses about 3.5 qt of oil out of 5 every about 1500 mi. I know it's low because the engine starts periodically rattling, I don't know which part but it's 100% correlated to the low oil level. I know the measure because I drained the existing oil in a bucket to see how much was gone. When I add oil, the rattling stops. The remaining oil didn't look particularly dirty:
This is the second time this has happened since I replaced my head gaskets last September so I'm worried if I didn't seal it right (as there might have been minor warpage on one of the V6 deck sides but very minimal just outside the factory advised threshold, which I guess is conservative) so I may be leaking oil into one or more combustion chambers.
The first time I thought it may be a leaky oil pan gasket so I replaced it (without much analysis because it was easy and the part was cheap). But it happened again. What I'm hoping is that the oil pan may be warped so it still leaks even with the new gasket. Because, in both cases, the amount of oil that was left corresponded roughly to the size of the oil pan.
I did check around the engine and everything looks pristine, no visible leaks on around the timing chain cover or cylinder head covers. Also no signs of leakage around the oil pan but then again it may have dried after it leaked down to where the joint is.
Considering the above symptoms and metrics, should I start suspecting the I'm losing it due to a cylinder leak and should I perform a cylinder leak down test, for which I have all the tools (though have never done before)?
RELATED: How to test if oil is leaking into combustion chambers?
UPDATE 1: Every single spark plug looks like this
UPDATE 2: I just did cylind er leak down tests on all 6. Pumped the left gauge to 90 psi on each cylinder, before making sure it was in TDC. The right one was between 75 and 80 psi on 5/6 and only one cylinder wouldn't go past about 65 psi.
Do these test results indicate a problem? Should the right gauge always be the same as the left one on every cylinder?
10
    Is your engine getting to 3.5 quarts low before you refill it? That's probably not good. Doesn't the dipstick indicate when it's 1 quart low? You mentioned "overhaul" in a comment, did you have new rings/pistons/cylinder honing done? That may take some time before it breaks in & uses less oil. And how's the coolant? If there's no leaks and no smoke then it could be getting into the coolant - or may just burn a lot of oil, but relatively cleanly with no smoke?
    – Xen2050
    May 5, 2016 at 5:03
  • Everything else is fine, coolant etc
    – amphibient
    May 5, 2016 at 5:04
  • When you changed the head gasket, did you get the mating surfaces of the head(s) machines (skimmed) back to flat? May 5, 2016 at 9:40
  • imho the only places that much oil can get into the combustion chamber is the PCV system or bad piston rings.
    – Moab
    May 5, 2016 at 16:11
  • @amphibient When you were having the leak on the 65psi cylinder, Did you listen at the oil cap or pcv to see if you could hear anything. The other two places to listen to would be the exhaust and the throttle body, but those would indicate bad valve seal in the combustion chamber. May 6, 2016 at 1:34
4 Answers 4
10
You can do a leak down test but look at your spark plugs first
If your burning oil you will see it on your spark plugs. They will be black and have buildup on them. If you find one or two that look that way and all the others are very light in color to tan then you probably have oil getting into the combustion chamber.
Here are some nice responses regarding performing a leak down test.
You can also do a compression test that's a little faster and may just tell you that one cylinder is considerably lower on compression than the others.
If you do have to remove the head, take it down to a local machine shop and have them make it flat while removing as little material as possible. If the head was torqued unevenly or was overheated prior to your ownership it could be slightly warped and creating recurring head gasket failure.
I think your definitely thinking along the right line, I would just check your spark plugs first. Physical inspection yields good data. Have a look at them for your first run on data collection then move onto harder things to do to gather more data to come up with a conclusion.
Good luck!
7
Not a desired answer, but with no leaks (to ground or into coolant) it's possible that your engine is just using/burning what some manufacturers would consider a normal amount of oil:
How much is too much?
Audi, BMW, and Subaru stick firmly to the statement that oil consumption is a normal part of a car’s operation. Subaru considers a quart burned every 1,000 to 1,200 miles to be acceptable. Certain Audi and BMW cars’ standards state that a quart burned every 600 to 700 miles is reasonable.
If a driver has to add a quart of oil once per month, that can mean adding up to 7 to 9 quarts of oil between oil changes. Those costs due to excessive oil consumption can add up because automakers more frequently require synthetic oils that can cost upwards of $9 per quart—in addition to the expense of the routine oil changes.
From Consumer Reports "Excessive oil consumption isn't normal - Automakers say adding oil between scheduled changes is acceptable. It's not. Published: June 30, 2015 06:00 AM
Also interesting news video here
And that's for new engines, yours is about 9 years old.
A cylinder leak down test would be a good idea, especially if you've already got all the stuff to do one, and should confirm some causes of oil consumption. A quick search for how to stop engine oil consumption found some advice from http://www.aa1car.com/library/oil_consumption.htm
CAUSES OF HIGH OIL CONSUMPTION
Oil consumption depends primarily on two things: the valve guides and piston rings. If the valve guides are worn, or if there's too much clearance between the valve stems and guides, or if the valve guide seals are worn, cracked, missing, broken or improperly installed, the engine will suck oil down the guides and into the cylinders. The engine may still have good compression, but will use a lot of oil.
engine valve deposits
Heavy carbon deposits on the valves are caused by worn valve guides and seals.
Worn valve guides can usually be restored a number of different ways. One popular method machine shops use is to ream out the guides and install thin bronze or cast iron guide liners. Knurling is another procedure that can reduce valve guide clearances. With aluminum heads, the original guides can be driven out and replaced with new ones. With cast iron heads, the guides can be reamed out to accept new valves with oversized stems.
If the oil burning is due to worn or broken rings, or wear in the cylinders, the engine will have low compression. The only cure here is to bore or hone the cylinders and replace the worn or broken piston rings
Correct oil?
OR, are you using the correct (viscosity) oil? There may be a thicker "summer" oil you could be using, or a "High Mileage" oil.
Or just trying a slightly thicker oil, even if it's not mentioned in the owner's manual (that may be a bad idea, that may have worked better with much older engines). (These are mentioned in the above "Engine Oil Consumption" linked page too)
There is probably a wall full of oil additives in an auto parts store to try too (most of which may just "thicken up" the oil anyway).
And please check your oil more often! Leaving just 1.5 quarts in a 5 quart engine sounds like it could be doing damage, that's probably what the "rattling" you're hearing actually is. The oil dipstick should indicate when it's about 1 quart low, use it!
  • @DucatiKiller :-)
    – Xen2050
    May 5, 2016 at 6:26
  • Nice indeed, but if the OPs figures are correct then the oil consumption exceeds even the manufacturer stated consumption, and even those are outrageus. Clearly it's burning more than it should. May 5, 2016 at 11:12
  • @IhavenoideawhatI'mdoing True, that's the main point of the Consumer's Reports article, that it's Not acceptable, at least for a new vehicle, but it shows a different perspective - but the "9yr old pickup with replaced head gaskets" is kind of a horse of a different colour. (The manufacturer's would probably now say it's time to buy a new vehicle, or at least engine ;-)
    – Xen2050
    May 5, 2016 at 11:39
  • yeah, when i did my tuneup, i did take each head completely apart and cleaned the valves and lapped them. could have introduce a condition with the guides that causes this. i did put all pieces back into the same place
    – amphibient
    May 5, 2016 at 16:33
7
I'm wondering if you are having an issue with oil bypass, as in going through the breather/PCV and ending up getting burned through the intake. A simple catch can would prove this out for you. This happens quite a bit and is easily solved.
Two things.
The leakdown test will not tell you anything about your oil loss. Its not what a leakdown test if for (check the link in the @DucatiKiller answer).
Secondly, the oil has to be going somewhere. I'll guarantee you if it was leaking in the amount you're talking about, you'd see puddles and/or oil on the engine itself where its leaking. That's a significant amount of oil to be leaking or for the engine to be swallowing, for that matter.
If you aren't noticing either puddles or smoke from the engine bay (not tail pipe), you aren't leaking it. Check the inside of the tail pipe(s) for oily soot. That may be an indication. It may be smoking from the tail pipe, but you may not notice it (people behind you while you are driving probably would though).
14
  • No smoke in engine bay or puddles. Soot in the tail pipe isn't oily
    – amphibient
    May 5, 2016 at 1:56
  • So if PVC were the cause, where would the oil go ?
    – amphibient
    May 5, 2016 at 2:27
    Into the intake and get burned in the engine. It isn't that the PVC is exactly the cause, it's just that the vacuum created can suck up oil sometimes in some engines. May 5, 2016 at 2:41
    Adding to the above, you could potentially have oil getting past your oil rings in the combustion chamber, but unless it was extremely bad, I doubt it would cause that much oil loss. I would suspect it's either leaking out somewhere else, or a pressurized source (somewhere in the head or block) would be pushing the oil somewhere else. May 5, 2016 at 12:37
    @BryanDavis - You are quite correct and were used as intended. May 5, 2016 at 13:08
I agree with Paulster2. Leak down test is about compression rings, not oil control rings. You can have good compression/leak down and consume oil. I would look at the pcv system. If there is too much "blow by" the pcv cannot keep up. Make sure there is vacuum to the pcv, and enough vacuum. A stopped up pcv vacuum port/line will cause excessive oil consumption and can cause leaks and/or oil consumption as pressure builds inside the engine. Fuel injected engines do not smoke like carbureted engines did. Looking at he plugs will help in figuring out where the oil is going. Dark, sooted plugs are oil burners. Whitish plugs are normal. PCV valves are cheap. I would change it and make sure all breather tubes are clear.
