My Taurus started to make a grinding noise in the front. When I looked at it I could see the ABS reluctor ring was grinding on the lower ball joint. My plan is to replace the axles/reluctor rings, but I was wondering if this may be from the struts weakening or something else.
4Possible bad wheel bearing.– MoabApr 30, 2016 at 20:28
1@Marty I concur with Moab. You are going to want to get this fixed pronto. Delay on this fix just generates more bad results and $$.– zipzitMay 2, 2016 at 3:07
1Jack up the front end, try to move the wheel in all directions and feel for play. if there is play, look where it is coming from.– rpmerfMay 2, 2016 at 10:28
