In my Toyota Vitz 2007 (automatic transmission), I have facing a problem for about a week now. The problem is, sometimes when I press the accelerator, engine revs up but car does not accelerate much.
If I release the accelerator and pressed again, the vehicle catches up and accelerates. The problem is more apparent when I am going up a hill.
Also, there had been another problem for some time now, that is, when I accelerate from a complete stop, car sometimes accelerates with 2 or 3 quick jerks.
I have changed transmission fluid about 20,000 km (about 2 years) ago.
Is it possible to check transmission fluid level in my car? I can't see any dipstick similar to the one for checking engine oil level.
Also my engine wiring harness has some problems and I have soldered several broken wires. Mostly due to this, the car idles roughly. I am looking for a new aftermarket wiring harness these days.
Could the wiring harness problem have a relation to the acceleration problem?
Possibly, if it is an electronic transmission
Not familiar with that model but some can only be checked if the vehicle is on a lift, manufacturers have started removing the usual transmission dip sticks and replacing them with really short ones than can only be accessed while on a lift.
Slipping of an automatic transmission is not good and will do further damage if you keep driving it.
  • The Vitz is like the Echo/Yaris in the States. Apr 30, 2016 at 14:31
Is it possible there is problem in your ignition system. I think there is conduction problem on your spark plug which is placed on the engine.
