I have a 2000 Honda Accord. When I trigger the windshield wiper fluid onto the front windshield, the right sprayer works fine but the left one seems clogged and it sprays very minimally. Because of this, I cannot clean my windshield fully and it usually streaks. Is there any way to repair this?
High Pressure Air
I would disconnect the hose from that sprayer from the motor that gives it the pressure to spray.
I would go where there is high pressure air. In my case that would be my shop.
I would have an air gun with a rubber tip.
I would take that air gun with a rubber tip and push it tightly against the sprayer nozzle and use the high pressure air to blow the offending particle backwards through it's windshield wiper fluid delivery hose.
Re-attach hose to wiper fluid delivery pump and spray away.
Here's a photo of the air pressure blow gun with a rubber tip.
I've managed to repair these jets (and re-align them) by using a dress pin pushed down the nozzle. Typically either dirt or polish (depending on how you maintain your car) accumulates at the exit point of the nozzle and a pin is enough to clear it.
If the blockage at the nozzle and you've got a Bowles Fluidic nozzle, the push pin method won't work. You will want to use compressed air. Not sure if Honda uses those but most Detroit based cars certainly do.– zipzitApr 27, 2016 at 19:05
Many manufacturers will recommend insertion of a pin to unclog a windshield sprayer.
It doesn't always work but is definitely worth trying before buying.
