I am no mechanic and do not have any mechanic knowledge etc and would like to hear from experts here regarding an issue.
My query ...
On a Mercedes CL500 (2002 model) the water pump, idler pulley & tensioner was replaced by a garage. The car was taken by the car owner after the repair works and was driven around. The following day, according to the car owner, after driving around, the car had to be recovered and was taken to another garage. Also, the check engine light was 'on'. The second garage upon inspection gave the following explanation to the car owner:
Upon inspection they found a poorly fitted water pump and so due to this the check engine light was on, whilst at the same time this restricted engine performance.
Due to the poorly fitted and damaged water pump components the vehicles air conditioning had three times more pressure than required and therefore they had to do some repair work on the AC side of things.
They further explained that the water pump plays an integral role in the fully functioning of the entire engine system pumping water the to the coolant radiator as well as assisting the air conditioning.
So my first question to experts here is that can a failed/poorly fitted water pump affect the AC system and as the second garage explained - make the AC system work under three times more pressure than usual?
What are the possible things that could happen due to a poorly fitted water pump and related components (i.e. idler pulley & tensioner)?
- the first that did the repair work did, according to them, do all necessary post work checks, also left the engine running for a while, taken for test drive and was fine before releasing the to the car owner
- No mention of what the check engine code(s) were
- No mention of coolant sign being on
- Bare in mind that the driver was able to drive car until the following day
- No explanation given why the car was recovered, or whether it was 'driveable' but still recovered
- there is mention of the coolant temperature display sensor being replaced by the second garage but that was 2 weeks after the AC related repair works were carried out by the second garage
Your input will be much appreciated.
