I've had this weird issue that has started happening since I switched back to summer tires this weekend that wasn't there last summer/winter. My car fights back when braking, but appears to pick a random side. I drove on the same road and braked at the same-ish spot and my car decided to tug in both directions.
At first, I thought this would be tire pressure, but when it happened to tug on the other side, I was convinced it wasn't. (After checking pressure, it wasn't)
Could this be my alignment or balancing? These are brand new tires on brand new wheels. It's also the transition between seasons which means there's a bit of sand on the road from the winter.
Otherwise I believe this leaves the brakes/calipers malfunctioning but I'm at a loss on how to diagnose this. Especially since the only variable changed are my wheels and tires.
