The check engine light came on very recently with two error codes being thrown. From this source, the following will cause 0507
P0507 HONDA - Idle Control System RPM Higher Than Expected
- A vacuum leak
- Leaking air intake after the throttle body
- EGR valve leaking vacuum
- A faulty positive crankcase ventilation (PCV) valve
- Damaged/failed/dirty throttle body
- Failed EVAP system
- Failed IAC (idle air controller) or faulty IAC circuit
This source says the following will cause 0011
P0011 HONDA - Variable Control Timing System Malfunction
- Dirty Oil
- Low engine oil level
- Valve Timing Control (VTC) open or shorted circuit.
- Valve Timing Control (VTC) electrical connector
- Faulty Valve Timing Control (VTC)
- Damaged ECM
What can I do to further identify the source of the problem?
