The shift lever is stuck in reverse and will not come out. I took out the shift tower to check the cable, and nothing appears to be missing or stuck. What could be causing this problem?
    So running or not, clutch in, you can't pull it out of reverse? With the car running, does the car actually travel in reverse like it should? – JPhi1618 Apr 21 '16 at 13:25
