Already having replaced 2 fuel pumps, both died.
Seems to have a problem in somewhere (alternator, battery, electricity) or I have no luck for fuel pumps.
The last one, last 6 months, before died completely, it start making a loud noises.
Vehicle: Dodge Charger SRT8 2009
On both fuel pump connectors there is a burned corner pin. No one in garage can tell me what is wrong with that.
Anyone got an idea what can it be ?
**** UPDATED QUESTION ****
So, after having tested an electricity, everything was fine, except that battery is about to die, but that's not a case. Alternator works fine, relay is fine, cable management should be fixed for the fuel pump, but that's just for a better future use.
The problem was: Somehow the fuel tank was extremely dirty, fuel pump engine died completely and the whole left part of fuel pump assembly was dirty, fuel pump filter was almost totally black from that dirt.
Now I think to go back to the garage where they previously cleaned my fuel tank, to do it in a proper way. In a meanwhile I have to order a new fuel pump.
Question is: is that possible that a dirt could make a pin to be burned ?
