Is this indicator controlled by a fuse?
How low is "dangerously low" in your case? – I have no idea what I'm doing Apr 18 '16 at 7:35
I had to add three quarts of oil to get oil level to bottom of dipstick. I was lucky I had stopped for gas on long trip. – Jim D Apr 19 '16 at 10:51
The oil level indicator on the CTS should be triggered by an oil level switch that screws into the sump. You should check that. I doubt it has a dedicated fuse. – I have no idea what I'm doing Apr 19 '16 at 11:43
Add a comment
