I had to replace the 2 brake lines that go from the master cylinder to the ABS control box. I bled all 4 brakes in the proper order, (RR,LR,RF,LF) but the brakes are minimal and the pedal goes to the floor. The master cylinder is full.
Also, I could not get the rear bleeder bolts loose and did not want to twist them off, thus I bled the rear brakes at the brake hose going into the caliper....Is this acceptable?
What am I missing?
Should I have attempted to bleed these lines at the control box?
Thanks.
