My jeep check engine light came on.
My volt meter went to 0.1. I changed the alternator and it worked for about 10 seconds and it went out. I installed another one and it did the same thing!!!
What is the issue?
    Did you read the error that caused the check engine light? Apr 8, 2016 at 7:25
  • 0.1 does not sound right at all, it should at least be showing battery voltage. Where were you probing? Ensure the connections are clean and tight, also that the battery connections are clean and tight. Check your grounds.
    – rpmerf
    Apr 8, 2016 at 11:04
  • @rpmerf Do most alternators have a rectifier built into them on cars? Apr 22, 2016 at 1:17
  • as far as I know they do. Haven't done too much with alternators aside from replace them when they aren't charging.
    – rpmerf
    Apr 22, 2016 at 12:47
  • @user16264 I think you need to provide more details. Are you talking about the in-dash volt meter, or a multimeter you connected? If you used the multimeter, where did you take the voltage reading? Apr 28, 2016 at 4:07
Your question is relatively vague, however there are a few things that could be at issue.
You could have a short circuit in your system that is draining the battery, which could also overload the alternator, causing it to fail. Since most of the circuits in a car are behind fuses, a short causing the problem you describe would have to be before the power distribution module (fuse panel), which means it's most likely something directly connected to the battery check:
  • Connection from battery to starter
  • Connection from battery to fuse panel
  • Connection from battery to alternator
  • Check the Alternator
It could also be a bad battery. If the battery was allowed to discharge to low, it won't take a charge anymore.
