I have a 1995 Mercury Tracer Trio that needs new tires. I do not have the wheel lock key/tool to remove them though. Is there an alternate way to remove them without having to take it to a mechanic?
Are you referring to locking lug nuts? Do you have a picture?– I have no idea what I'm doingApr 8, 2016 at 7:24
1It depends on the type of nuts fitted - Some can be removed with readily-available tools, others will need to be taken to a professional... As @IhavenoideawhatI'mdoing says, could you please post a picture?– Nick C ♦Apr 8, 2016 at 8:46
Look on amazon for the key– rpmerfApr 8, 2016 at 11:01
Just posted a picture. I've even contacted a Ford dealership and the technician told me that he doesn't have keys for that old of a vehicle.– Christopher ChippsApr 9, 2016 at 18:20
You can use a wheel lock removing set.
I believe most automotive stores will sell them. They can also easily be found online.
Or you can drill the nut and stud. Which takes a long time. It would be faster & cheaper to pay a mechanic for a half hour labor to remove your wheel locks.
It takes one upvote to get the question marked as 'answered' OR if it get's accepted with even if there aren't any upvotes. Apr 9, 2016 at 19:14
I suspect you'll have to take that to a shop - I had a very similar set of locks on a car before, I tried using a remover set like the one in Ben's answer, but it didn't get anywhere - the outer chromed ring split in two circumferentially and just span - the tyre shop used a special single-use tool that was hammered into the keyhole and deformed to fit.
