Is there any way to detect AC(air conditioner) and Window(open/close) using OBD?
I am putting links below for the OBD reader but I am unable to find any way to detect the AC(air conditioner) and Window state (open/close).
https://github.com/pires/obd-java-api
https://github.com/pires/android-obd-reader
  • Thanks @IhavenoideawhatI'mdoing . Check my updated question.
    – pRaNaY
    Commented Apr 5, 2016 at 7:22
  • As I understand you want to read whether the AC is on or off and which windows are opened and closed via OBD? I don't think there are such PIDs defined by the SAE J1939 standard. That doesn't mean your vehicle does not support these, some manufacturers add extra PIDs. However I personally haven't seen them available before. Commented Apr 5, 2016 at 7:33
Those OBD-II PIDS are NOT part of the standard OBD-II spec - they are manufacturer specific and not governed under OBD-II
That being said, I know for a fact that you can get this data if your car is a Daihatsu Copen as I have done it
