I own a Ford Focus 2008 1.6 TDCI. Recently I filled the DPF Additive tank with EOLYS Fluid but I couldn't regenerate and reset the values that day, so I drove to my home.
Following day, I went to work at my lunch time. I took my car to the repairman to regenerate and reset the values.
The problem started showing up after it had been completed successfully, the IDS was showing an error:
Does anyone know what the issue might be?
Error Code
EDIT:
P.S. forgot to tell that a year ago I had ran out of fluid, I couldn't find any solution and fluid for around 3 or 4 months. When I found the fluid I bought only 1 liter(they said it's enough). For the next 2 months everything was ok, then it started showing me P2584 error code until now that I have filled it full
  • Interesting. Have learned more about the issue that you can add to your question? – DucatiKiller Apr 5 '16 at 1:24
