I'm trying to install these multi-color dome lights, I successfully installed the right side, but when I tried to install on the left side, the left one won't work. The product is not the issue, I tested it and the product works. When I install the original dome light, that works fine. Any thoughts?
Thanks!
    Are these LED's? and...what is the make/model/year of your car? You might have a BCM (body control module) or some other component that doesn't like the wattage.....or.... Commented Mar 30, 2016 at 23:53
    ... or if they're LEDs and have positive/negative reversed. (and not reversed when you tested it.)
    – Tim B
    Commented Mar 31, 2016 at 3:26
  • These are LED dome lights, I checked by switching sides, it wasn't the problem. I have one dome light installed on one side, it's just the driver side one that doesn't work. The car is 2012 Ford Taurus. Commented Apr 1, 2016 at 2:46
