The previous owner of my Honda Hornet 900 was a brilliant mechanic but a terrible electrician. They added some extra lights that are beautifully fitted but wired illegally. There's a basic switch on the handlebars that turns them on but if you turn them off and immediately on again they switch mode:
- High beam.
- Low beam.
- Flashing.
To make it worse they wired them into the headlamp so they're only on when the headlamp is full beam. That means if I ride at night and change the headlamp from full to low to full then they change mode which makes them illegal (in New Zealand).
I want to get the lights open to see if the control for the modes is in there but I can't figure out how to get it open. Is this a standard part or has it been specially machined? There's no model or serial number on the outside.
More photos here.
