Has a fresh top end. Carburetor cleaned. Fresh fuel mix. Reed valve looks ok. Air filter and intake, ok. Has good spark. After it dies, the plug is wet.
Restarts after cleaning plug?
I checked the stop switch and harness. I inspected wiring and connectors, ignition coil primary and secondary circuits. Checked for intake air leaks. Runs great than just dies and fuel fouls the plug.
Could a malfunctioning or maladjusted power valve be causing this?
How do I check and adjust them?
Also, could it be the carburetor power jet solenoid?
How do I test it?
