The car is still starting flawlessly but some accessories like the radio or the clock don't always work.
I noticed that pushing the key deeper in the ignition would make the radio start, but releasing it will make it stop most of the time.
I had a look at the ignition switch (see pictures bellow) and found out that the electrical switch (the black thing on the left) is loose by more than one millimeter. Sure enough, when I keep it in position, everything is working as expected.
I managed to unplug the electrical connector, but I couldn't find how to remove or re-attach the black part to the main part of the ignition switch (see the third picture).
My questions are:
- How to disassemble the black part from the ignition switch
- How to reassemble it in place (since it works when I push it in place, if I can just replace it correctly it should work without need to replace it)
