I've been looking all over trying to see if there is any information but I haven't found it. I'm about to replace the spark plugs, but I need to know the correct gap. I purchased NGK 4696 Iridium spark plugs. I'm not sure if the same gap will give the same amount of power.
    If you bought plugs for your particular car, they should be pre-gapped correctly. Measure them to make sure, but they should be correct at I believe .040 or .039 (1mm). Do you think they are wrong or not for your car? – JPhi1618 Mar 14 '16 at 16:49
    Did you check on or around the core support area in the engine bay? I don't know about overseas, but here in the States most vehicles have an emissions sticker which tells what the plug gap should be. – Pᴀᴜʟsᴛᴇʀ2 Mar 14 '16 at 18:05
    Be careful, Iridium spark plugs are really easy to damage when gaping. The center electrode is very fragile. – vini_i Mar 15 '16 at 1:04
