So before I speak to a garage I thought I would ask your opinions here.
I have a 2005 Facelift Vauxhall Corsa C. I've had the brakes and shock absorbers replaced - this was done soon after I bought the car.
Recently I've noticed that if I go full lock when turning I get a knocking sound - putting this down to knackered CV joints.
When driving at any speed over 15mph there is quite a loud rumbling/humming sound inside the car, I mean it is really noticeable, what would you say this is? Possible hub issue or perhaps a wheel bearing?
Also when I go over bumps in the road there is a very loud creaking coming from the front. One idea I had was anti roll bushes needing replacing but not sure, opinions welcomed on this.
There's no doubt I'll be going to a garage to sort this soon but having some idea would be really appreciated :)
Thanks, Andy
  • Have you checked the torque on the front (well all really) lug nuts? Loose lugs will give you a lot of the same symptoms you are talking about. Mar 9, 2016 at 23:42
  • I haven't yet no, I'll try and take a look this weekend Mar 10, 2016 at 7:31
  • Can you take some video and post a link so we can hear what you are describing? Mar 11, 2016 at 0:26
  • I'll do that on the way home :) I think it's a wheel bearing, incredibly loud humming Mar 11, 2016 at 9:05
  • Definitely a wheel bearing btw, garage fixing it next week :) Mar 19, 2016 at 19:41
OP has indicated that this is a wheel bearing issue.
Definitely a wheel bearing btw, garage fixing it next week :) – Andy Holmes Mar 19 at 19:41
Completely forgot to follow this up. I got it fixed and the car no longer sounds like a jet engine – Andy Holmes 1 hour ago
  • Completely forgot to follow this up. I got it fixed and the car no longer sounds like a jet engine Apr 5, 2016 at 6:31
    lol...awesome. As well, you can answer the question and award the answer to yourself and share details regarding the resolution. Thanks. Apr 5, 2016 at 7:34
Okay so DucatiKiller has taken on keeping an eye on this question as I totally forgot to get back to everyone lol. Here's a basic rundown of what's going on with the car and what happened when I took it in for repair:
The loud humming was indeed caused by a damaged wheel bearing, you could also feel the vibrations in the peddles and in the steering wheel - the vibrations would usually be most obvious between 30mph and 50mph.
I took it to the garage and an hour later the N/S/F (Near Side Front) wheel bearing had been changed and now it sounds and drives so much better. Around £48 for parts and £50 for labour costs + the usual 20% VAT here in the UK.
The creaking going over bumps is likely to be wearing wishbones/wishbone bushes and the CV joints are definitely wearing but no need to change them anytime soon.
Hope this info helps anyone in the future :)
