7
Bought some redex "shots" for my 2003 Opel Agila 1.2 petrol.
Do I just fill the tank and then pour it in?
How do I use it?
How often should I use it?
8
From the Redex website:
How do I use it?
Simply pour Redex directly into the tank in the same way you add fuel. The bottles have been designed with a long neck which inserts like a fuel pump to make pouring easy.
Redex can be used as often as you like to keep your engine running well. We recommend using a shot in each tank, but you can also use it whenever you notice your MPG dropping or between fill ups.
