Why would I want to magnetize my screwdriver?
and
How would I magnetize my screwdriver?
  • In my experience they magnetise themselves. You're more likely to want to de-magnetise them.
    – user207421
    Commented Feb 28, 2016 at 19:16
8
If you dont want the screw to fall off the screwdriver when you are putting a screw into a difficult place the a magnetic screwdriver is useful.I find that it works well on small screws like M3 phillips .If you are undoing a screw then the screw stays attached to the srcewdriver greatly reducing the likelyhood of loosing the screw. I magnetise my screwdrivers when needed by simply rubbing them against a strong permanent magnet .The permanent magnets are from dead loudspeakers and are normally employed as fridge magnets.
  • 3
    Just make sure when you rub the magnet on the screwdriver you always rub in the same direction. If you go back and forth it won't magnetize.
    – cdunn
    Commented Feb 28, 2016 at 1:50
