I have replaced all 4 oxygen sensors and OBD II code still shows codes P0053, 54, 59, and 60. What could be causing this and how do I fix it?
The O2 sensors have 2 white and 2 black wires. Exactly which red/yellow wire are you referring to?
Sign up to join this communityI have replaced all 4 oxygen sensors and OBD II code still shows codes P0053, 54, 59, and 60. What could be causing this and how do I fix it?
Check fuse 21 in the under hood fuse box. If the fuse is OK at one of the o2 sensors check for power on the red/yellow wire. If you have no power at the o2 sensor I'm afraid your going to be looking for a short to ground. Which would involve tracing the wiring harness and visually inspecting for rub through or broken wiring.
The Red/Yellow wire is in the harness, not on the O2 sensor.
It's can only be something that effects all 4 sensors. The ground is provided individually for each sensor by the PCM so it can't be on the ground side.
Power is provided by Fuse 21, but that also powers the EVAP canister vent valve so if that fuse was blown it would also set an EVAP code, but you defiantly have a problem on the power side of the harness. Shortly after the Red/Yellow wire leaves the Fuse block it splits off from the EVAP circuit and runs down near the right side headlamp, along the right inner fender (under the finder skirt if I remember correctly).
Trace that wire from the fuse box to the O2 sensors, you will likely find a damaged harness along the lower right fender area. You will have to get to it from the bottom of the car. I have had at least two different Crown Vics with damage in the same area. I believe it's a common failure.
After replacing the sensors- did you clear the codes and drive the car on the highway for a while so that the car computer can re-read the cars activity codes? After finding the codes and performing repair, you should clear codes before trying to get another code reading. Try clearing your codes first. No promises here- but this maybe just what you need.
