9
On a separate forum, someone had asked why electric cars do not have transmissions.
The simple answer was that electric cars produce peak torque at any RPM but the gasoline engine needs to rev up to certain RPM to churn out similar power & torque figures.
Can someone explain why is it so?
3 Answers 3
10
Torque in almost all electric machines is a function of current. For permanent magnet machines, torque is roughly proportional to current and for the series-wound machines, torque is roughly proportional to current squared. So if you can get the current in quickly which is easiest at standstill, you will burn rubber.
  • Good point, explanation on why gasoline engines produce torque at certain rpm will be helpful
    – Shobin P
    Feb 11, 2016 at 11:53
    @Anarach it requires quite a lengthy explanation, but a short version would be because internal combustion engines, unlike electric motors, require air for generating torque. And torque depends on how well the air is ingested - volumetric efficiency. Volumetric efficiency depends on engine RPM, which is why such an engine generates the highest torque at a certain RPM point. Feb 12, 2016 at 14:01
    There are also MANY factors that go into the RPM max torque is obtained. Bore, Stroke, # of cylinders, compression ratio, # or valves, size of valves, cam lift and duration, port sizes, port lengths, restrictions in the intake and exhaust
    – rpmerf
    Feb 12, 2016 at 16:42
To expand on @Autistic's answer…
There is no need for a transmission with an electric vehicle (assuming that the speed and characteristics of the motor match the application – for applications where this isn't the case electric motors are often coupled with a gearbox to (usually) reduce the output speed of the motor to something usable) because an electric motor produces maximum torque at 0 RPM.
An electric motor is basically a short circuit – it's just a long hunk of wire wound up in a coil. The only thing that prevents a motor from tripping its circuit breaker or blowing its fuse is the back EMF (electro-magnetic force) that is generated when the motor is spinning. As a result when the motor is stopped (or when something tries to slow the motor, such as when a car is asked to climb a hill) there is initially a large inrush of current. This changing current in the motor's windings produces causes a magnetic field to build and the changing magnetic field is what generates the back EMF which resists the current rushing through the motor. So, as the motor comes up to speed the current (and torque) are reduced until an equilibrium is reached.
But that's not the case with an internal combustion engine, they have to be spinning to produce any torque at all and they typically (always?) have a relatively narrow RPM range in which they develop best torque. The transmission provides a way to match vehicle speed to the RPM range where the engine produces its best torque.
Primary reason that ICE doesn't give instant high torque (power) is due to the time it takes to downshift several gears to get into it's high power range. Electric motors are often near their full power at both lower and higher speeds. That is at half of the maximum rpm it may produce twice the torque compared to the torque produced at maximum rpm, in which case the max power is produced at both half and full RPM. Few ICE engines can produce maximum power across the RPM range like an electric motor can, although with modern electronic control of an ICE turbo/super charger, one could get close once outside of the high idle range.
    You start off by talking about torque, then about getting into the "high power range", which refers to horsepower ... there is a relationship between TQ and HP, but they are not the same thing. Really, what you are saying doesn't make much sense. Nov 10, 2019 at 17:40
