Basic Functionality
Image In order to illustrate a typical Multimeter
The Multimeter is specifically a multifunction tool. By definition it combines several, well defined instruments and multiplexes the controls for simplicity.
Inputs
Majority of Multimeters will have 3 input terminals. Typically you will only use COM
and V/mA/Ohm
input (often Black and Red respectively, but not in the sample image). The third input is used for measuring particularly large currents. Some multimeters have 4 inputs for more precise measurements using Kelvin Sensing . In handheld devices this is typically seen on LCR Meters.
In Voltmeter mode you must always perform measurements in parallel with the circuit being measured, the circuit is powered
The basic functionality of the voltmeter is to measure voltages, potential differences across two points in the circuit. Virtualy all DMM's will have voltmeter functionality.
On the representative device shown in the image, the voltmeter modes are selected between 9:00 and 1:00 on the clock face. The flat bar represents DC mode and the Wiggly Line represents AC current. Either mode can safely be used interchangeably (affecting only reading accuracy) provided the voltage ratings are respected. Some multimeters will offer autoranging feature that does not require you to select the range explicitly on the dial.
Some ways you can use the DMM in voltmeter mode for automotive purposes
Establishing the presence of a control voltage on a signal line e.g. relay control line, fuel injectors
Establishing the presence of a supply voltage on various circuits
Measuring the voltage output of the regulator/alternator or battery
In ammeter mode you must always perform measurements in series with the circuit, the circuit is powered
The basic functionality of the ammeter is to measure electric current. In ammeter mode it will damage the DMM and possibly blow a fuse on the car if you connect your DMM in parallel to a live circuit, that is - in a way that it would measure a voltage were it in voltmeter mode.
On the representative device shown in the image, the ammeter modes are selected between 1:00 and 4:00 on the clock face. Note that the highest range setting on this device (and many others) requires you to use the alternate high current input.
Using an ammeter, when diagnosing a live circuit that should be on (e.g. lamp with switch turned on), the reading you get will inform you of the kind of fault on the circuit, a high current reading means a short circuit, a zero current means an open circuit.
Some ways you can use the DMM in ammeter mode for automotive purposes
- Testing for leakage - battery current when the car is turned off
In ohmmeter mode you should perform measurements in parallel with the circuit, the circuit must be unpowered
The ohmmeter measures the resistance between two terminals. The resistance determines the amount of current a device will draw at a fixed supply voltage. Typically "analogue" components on a car like lights, relays, switches, fuses, etc. will have a relatively low resistance, several ohms to 100 or so. Resistance for other components (e.g. sensors, injectors) can be compared against specification to detect failure.
On the representative device shown in the image, the ohmmeter modes are selected between 6:00 and 9:00 on the clock face. Note that on this device, the 2,000 (2k) Ohm setting is multiplexed for continuity readings (more on that later), secondary modes is often selected with the ubiquitous "conspicuous unmarked button". There is no harm (except the risk of getting no reading) in selecting the wrong range on the device
Some ways you can use the DMM in ohmmeter mode for automotive purposes
Verify the resistance of electrical components like injectors, lights, relays
Identify short circuits and open circuits, sometimes you have very low ohm "not-so-short circuits" that will not trip the continuity meter beep
Verify the continuity of a fuse
Additional Modes
Capacitance
Rarely seen on cheap DMM's and never on automotive ones, used to verify the capacitance. Lots of caveats for use and not the most useful feature for automotive repair and diagnostics
Continuity Tester
Somewhat redundant to the ohmmeter mode in terms of diagnostic capability. The primary benefit is the loud BEEEP, that it emits when there is continuity, allowing you to focus your eyes not on the dmm
Diode Testing
Often multiplexed with the continuity mode, the reading it gives you while measuring continuity is the voltage required to make the diode conduct.
Duty Cycle
Useful automotive feature, allows diagnosis of electrical engine components that use Pulse Width Modulation - e.g. injectors
RPM Meter
Useful automotive feature that detects engine RPM from the noise induced on a supply line.
Transistor Characterization
The funny "hfe" mode and three pin connector is for testing transistor beta . Somewhat of a gimmick and not useful for automotive purposes
Temperature Reading
If your DMM has a funny yelow connector with the K symbol, this is for Thermocouples. The DMM should have a "C/F" mode for measuring the temperature. The probe type is important so match the letter type.
